I am trying to remove the belt pulley from the transmission shaft I have a long 1 7/8 socket but I am not sure which way to turn it can anyone help please? I have tried both ways but so far no luck.
The nut is on fairly tight and held in place by loctite 262 so you will need to use a fair bit of heat to break the loctite bond
And as has been stated a left hand thread
