free website stats program Trouble Code Question | Harley Davidson Forums
tfj21709
I have been having some problems with my 2007 Dyna FXDB and I checked for any Diagnostic Trouble Codes this morning. I had two codes under the TSM/TSSM module reading: 61123 & 61155 but I can't find what these codes mean anywhere. Can anyone help? Thank you.
Hoople,
Thank you, I guess the initial 6 instead of the B was mixing me up. Do you have any idea what might be causing this?
You never said what the problem(s) were.
Is the neutral light working like it should? Does it light when in neutral and go out when in gear?
Are the turn signals working like they should? Do both front and rear bulbs work/blink when activated with the turn signal switches on the bars?
If YES to both, I would clear the codes and ride the bike to see if the codes come back.
I recently had clutch plates replaced and after picking up from repair neutral light comes on and most recently the red key icon came on with engine icon coming on intermittently. Any ideas?
