Police Harley
Diagnostic code is "No rSP"
I thought to myself, self, that could mean no rear cylinder pressure.
Scenario... caught in traffic on freeway due to wreck, 1+ hour at 10 mph...(not good for air cooled bike) check engine light comes on, goes off, comes on, goes off.
Ride to cool engine off after traffic, light comes on when I get on throttle, stays on for 10-15 secs goes off.
Smart Soldier thinks, time to stop at HD in winchester.
Yep smart move...heat protection mode stuck. Dealer clears it and test drives it. GTG.
On way home, wicked vibration, not smooth.
Smart me pulls off and does diag (watched the guy at dealership), code No rSP, can't get it to clear.
Common sense says, self, check plug wire, plug etc. Found plug wire loose and plug not tight....doesn't seem right , borrow spark plug wrench and since plug down and ensure plug wire set right. GTG ride home uneventful except code won't clear. (this was all last weekend)
Went to local recommended shop and they clear code with reader, look at the stuff I did, confer with another dealer and say GTG.
Bikes running great, smooth V-Twin vibe.
Go on ride today, no problems until I get on the freeway to come home(about 190miles into ride), feel that vibration again...
Get home and diag.. same code, but plug and wire are tight.
:unsure
Do some digging and see that this is not a new occurrence with the rear cylinder in Harley's.....however......
Could this really be a plug or injector?
When I work through the diag settings,
P= none
S= no rSP
S= none, then gives a Pn and numbers
ST= none, then give Pn and digits
t= none, then gives same Pn and St.
Thinking me says these are part numbers which may need to be replaced...am I on the right track?
I would be very grateful if someone could provide a bit of guidance and support as this is my first Harley after 20+ years of riding.
I really like the bike and have some resto plans in store for it, but don't want it to be a money pit, have to sell and go back to gold wing or yamaha.
PMCS is habitual being in the military, and I have no fear of getting hands dirty, but this is beginning to :bigsmiley19:
:unsure
P= none
S= no rSP
