I have seen a few posts on internet, but not on "hdtimeline" that if LED turn signal lights are installed front and rear, that a load equalizer may not be needed.
The "theory" is that the TSSM, after hitting each turn signal switch 5 times in a row, will reset itself to recognize the lower load from the LED bulbs.
Can someone debunk this for me? I am not advocating this method, only curious if it might be correct.
Thank you.
Thank you.
