DadzLowrider
Hey everyone-
Two questions:
1) can anyone tell me how to get to the wiring for the ignition switch located in the down tubes and which wire goes to where on one of the 3 tab dash mounted switches?
2) I have an 08 Low Rider and am switching to a FXDSE Dash with the ignition and the turn signal, brights and other warning lights in the dash. I need a new riser clamp since the stock one has the indicator lights built into it. Went to the HD dealer today and they couldn't find one that fits my bike. My bolt holes are straight up and down, not offset like on the Sportsters etc. Any ideas?
Thanks in advance for any help.
Ok- so I see the wire harness under that little plastic cover for the ignition. Is there an easy way to get to it? Does anyone know what gauge wire I should use to extend the wires? And lastly, anyone know what the best way to route the wires up to the console on the dash is? Should I just bring the out of the hole on the side of the next and then under the console? Or is there a better way? Thanks again in advance for any help.
Two questions:
