Marcus Thomas
Hello, I'm rewiring my 99 Fatboy Custom. The existing wiring harness is a spliced up nightmare. So I decided to do a complete re-wire. Has anyone used this harness? The harness has a control box that has relays in it as well as flasher control. The accompanying wiring diagram is pretty straightforward looking, but does NOT indicate if circuit breakers or fuses are to be spliced in. This is my first time doing a re-wire. The existing harness has three circuit breakers. Should I splice in circuit breakers also, or are they needed with this kit? Also, I have a Screaming Eagle ignition box (dual fire modual in the cone) Is this kit compatable with the screamin eagle ignition? Thanks for any advice/help.
