B bakdrft Member Sep 13, 2011 #1 Anyone ever see this B4? 2010 FLHX [/url][/IMG] let me know John O Last edited by a moderator: Sep 13, 2011
G glider Veteran Member Sep 13, 2011 #2 Harley Davidson Community swing arm water TT413.pdf Last edited: Sep 13, 2011
B bakdrft Member Sep 13, 2011 #4 Glider, Thanks the bike is still in warranty. I will follow up with the Dealer. John O
HDDon Experienced Member Contributor Retired Moderators Sep 13, 2011 #5 glider said: Harley Davidson Community swing arm water TT413.pdf Click to expand... You are without a doubt "The Go To Guy"!!!!:majesty:majesty:majesty
cavs1429 Member Sep 13, 2011 #6 drain hole on swing arm is blocked by the belt guard. Just loosen up guard three screws look to see where the drain hole is then drill throuh belt guard tighten screws. iTS THAT EASY
G glider Veteran Member Sep 13, 2011 #7 HDDon said: You are without a doubt "The Go To Guy"!!!!:majesty:majesty:majesty Click to expand... We keep on trying anyway
