Hi, thanks so much for the info! One more question, if you had a bike that had not ran since 1972 and is in good condition, what would you fix first? Thanks again for your time,Chemical cleaning:
Phosphoric acid: Fill the tank with a solution of phosphoric acid, cover the opening, and shake to coat the entire interior. Let it sit for the recommended time (usually 10-15 minutes), then drain completely and flush with water to remove any remaining chemicals. Let it dry completely before sealing.
Other options: Depending on the severity of rust, you might consider using a commercial rust removal product designed for fuel tanks.
You can look on Youtube as well for more ways. A quick look on Google you can find sealers designed for gas tanks.
A good product to treat rust is OSPHO, it contains phosphoric acid. Hard to find in some locals, ACE hardware in my town carries it. Pretty much use it as above instructions. There are also rust products that are more environmentally friendly avail at local auto parts stores, but I've not had much experience with them.
Hi, I was able to find this product and it seems pretty good. Thanks so much for the info!A good product to treat rust is OSPHO, it contains phosphoric acid. Hard to find in some locals, ACE hardware in my town carries it. Pretty much use it as above instructions. There are also rust products that are more environmentally friendly avail at local auto parts stores, but I've not had much experience with them.
