Marcelo Knust
Dear friends,
Not sure what happened to my post. Anyway I decided to post again.
Just wanted to share with you the scary experience I had this morning.
My outer rear brake pad simply dislodged from caliper slot during the ride, hanging just from the tab pin. No rear brakes at all.
The friction material was with 2mm thickness, after 6.250 miles.
My question is: is it normal or something that we should expect that a pad can dislodge from caliber slot because the friction material worn to a critical thickness? Have you ever heard about this?
I have never experienced such a thing with any automotive braking system!!!
Whatever the explanation, it seems to be a design problem...
Many thanks
Marcelo Knust
Dyna FXDC 2008 - 6.250 miles.
Rio de Janeiro - Brazil
Many thanks
Marcelo Knust
