RibEye
Senior Member
Gents,
The self-help area is gone. Sad, but, it is what it is. Lets see what we can do rebuild something good, by sharing what we know, and helping each other as we always have.
I would like to know what you know about how to recognize a mal-adjusted steering head (fall-away).
What can you notice if set too tight? What damage can occur if too tight? How dangerous is the bike to ride if too tight?
What can you notice if set too loose? What damage can occur if too loose? How dangerous is the bike to ride if too loose?
My immediate need relates to a subtle handling issue on my '03 RKC. I has a barely perceptible feeling that feels kind of like I'm riding through an oil patch, kind of swimmy, similar to a low rear tire. I also had a high speed wobble event some time back, but not in a curve. I was going in a straight line, but has a pretty good cross-wind.
I can re-create the oil patch, swimmy feeling by a gentle and very slight left/right wiggle of the handlebars. In my opinion it is too easy to do this wiggle. I have a Woody's fairing on my RK so there could be some amplification due to the additional weight on the front end, but it seems to be getting worse, and it definitely did not exhibit this when I first started using the fairing, 2 years ago.
I suspect that a loose front motor mount or vehicle alignment connections, or low rear tire pressure could make a similar feeling. Tire pressure is fine. I'll check the front motor mount and alignment connections in a few days, when I change my engine oil.
Enjoy,
Rich P
Enjoy,
Rich P
