To get the most accurate answer,you NEED to know your bore size.And obviously,yours is now slightly larger than stock.
Basically the formula is
i
x radius squared
x your stroke(this gives the SWEPT volume of EACH cylinder)
x the number of cylinders in your motor.
Let's have an example:my Triumph Daytona has a capacity of 955cc and is a 3 cylinder motor with a Bore of 79mm and a Stroke of 65mm.So ,with my trusty and oh-so-necessary calculator i work it out like this:
Pi(3.142) x radius squared(radius of 79mm bore is 39.5mm; so 39.5 x 39.5) x stroke(65mm).
This gives the volume of EACH cylinder;then x 3 for total motor capacity.
3.142 x 39.5(squared) x 65 =3.142 x 1,560.25 x 65 =318.649.85cc per cylinder.3 X 318.649 = 955.947cc
Substitute your Harley bore and stroke and number of cylinders and Voila!
Can't help with
your exact capacity,but that's how you do it.
Numbers are so magical.
