free website stats program What ignition module | Harley Davidson Forums
vtbikers
I have a 2003 1200 custom with a bad ignition module. I was going to replace it with the screamin eagle module ($119.95) that was listed in the 2009assy catalog.
But I have found out that they don't sell it anymore. The only module that HD has is the stock module($255.00). Is there anything else available in the
$100.00 to $200.00 price range. I have looked at quite a few more expensive modules, but really don't want to spend that much money.
Thanks
As crazy as it sounds HD Australia may be an option. NZ sources all HD /SE gear from Aussie and i think the unit you are after is the same as the one i got recently.
Thanks
Plenty of aftermarket options. But you need to decide what you want in terms of the ignition system capabilities. Read up on a few of the mfgrs. website to see:
Spyke, Inc. Acculight Ignition System
Dynatek Performance Electronics - Harley Davidson Dyna2Ki
http://69.20.53.62/pdf/90003200.pdf
Compu Fire Electronic Components for Harley Davidson Motorcycles
ACCEL Motorcycle :: Products
This list is NOT comprehensive, just a starting point. But also check here:
How Ignition Systems and Components Work - Harley Davidson Community
