So how does the inner cam bearings get oil other than the assembly lube you use during installation? Does oil weep into the outer edges of the race when running?
From '07 FLH service manual.
"The oil splash and mist created by the action of the flywheel lubricates the crankshaft bearing and the camshaft needle bearings in the right crankcase half".
