risuperglide
My stock 2010 FXDC has a 160 mm rear tire. What is the widest tire I can go without doing Mods?.......:hii
180 is as wide as you can go on the Dyna without more mods. Do not, I repeat do not, waste your money on the wide tire kit, just buy a 180 tire. As long as you have not lowered the bike you will be fine. Now if you ride 2-up you may need it. All you are really paying for is a SE 180 rear tire and some brackets. If you plan on putting bags on or relocating your rear signals then the brackets are useless...With that said if you want a set of brackets, I'll sell them to you cheap, just took them off my Dyna (I wasted the money), then you can go get a 180MM tire that you want, if that is your desire. The instructions for the wide tire kit you can find in the self help section, and I posted a bunch of pics previously of the wide tire kit install.
Here is the link to my wide tire install
Wide Tire Kit Installation - Harley Davidson Community
I already installed HD leather bags,& relocated my turn signals to the rear fender by the license plate. I ride with a passenger on occasion. Will I be alright with just installing the 180 Tire?
Yes, you will be fine. You won't need the brackets that come with the wide tire kit. Just go ahead and get the 180 tire you want.
