There are several differences. Your rear tire is a 150, '85's had 130, so the rim may be narrower. Both use 34" axle (I think), but '85 uses 2 piece taper,and '02 uses sealed. There may be a difference in bearing width, which affects spacer width. They will fit, but it may require more aggravation than you want.
