Hi everybody,
I have a 2010 Streetglide with ABS. I have always flushed my own brakes on my bikes, because I don't trust anyone else, and I'm super picky. According to my service manual, and several dealers I have talked to, I can't flush the brakes on this bike, because it requires the "digital technician."
Can someone explain why this is so? If the bike / ignition system is off, and all I do is open the master cylinder, attach a vacum bleeder to the caliber bleed bolt, suck new fluid through, then tighten everything back up; how will this screw anything up, and how will the ABS system even know I did anything. Further more, even if the ABS system did detect a change, isn't the system designed to simply revert back to conventional non-abs braking if the system detects an ABS error?
I don't get it!
Thanks!
I don't get it!
Thanks!
