Spade5
I did look in the self help section and didn't run across replacing the rear brake pads. I was cleaning up the rear wheel and started looking at the brake caliper and how it is mounted.
I am not looking for a step by step with photos but am curious how you change these rear pads. It doesn't appear that the caliper can be easily removed like the front. I am not familiar with other HD models but it appears the rear bracket and caliper are one piece and the rear axle goes through it.
