Okay, I'm finally getting ready to install the Black Typhoon rear tire, as soon as the money comes in I'm placing the order. With that I am thinking I'm going to put the wide tire kit on the Bob.
Now my question, has anyone here done that? Any thoughts on doing this?
I'm thinking I probably could, but my only concern is wheel alignment. Any thoughts on the difficulty of this?
Else I think I'm going to have to find a local Mechanic cause I don't think I want to take it to HD.
You do not need to mess with wheel alignment when you remove and install a rear wheel.
Pretty simple to do. If you need stuff out of the manual to read ahead of time, send me an
e-mail.
Jack the bike up till the bottom of the tire is just ready to leave contact with the ground. Make sure the bike is strapped down (when the wheel comes off, all the weight will shift to the front of the bike). Remove rear axle nut and the clip from the left side of the axle. Remove Lower shock bolts. Pull axle. If it has not been off before, you may need to beat it out, Thread axle nut halfway on before you beat on axle. Pay attention to the position of teh wheel spacers so you can put them back correctly when you reinstall the wheel. After axle is out, raise jack and bike. Make sure straps have slack and allow you to raise it. Slide rear caliper off rotor and off caliper guide on swing arm. Slide belt off pulley. Move wheel out from the rear fender.
Basically, the install is the reverse.
Apply a good coating of named brand anti-seize on rear axle before reinstalling. Try not to get anti-seize on tire. Its messy and can be dangerous.
Make sure all fasteners are torqued to specs.
Use red Loctite on pulley bolts and caliper bolts when you change wheel.
The alignment has not changed using this procedure. Alignment is only necessary if you move the axle adjusters to relieve tension on the drive belt. Dropping the rear shocks accomplishes the same thing without having the do alignment or adjust belt tension.
If you had to remove exhaust in order to remove rear axle, reverse the axle's direction when you reinstall it. Install it from the rleft to the right side. This will put the axle nut on the right, near the mufflers. Next time you go to remove the axle, you will have plenty of room as the exhaust will no longer be in the way.
Good luck
