This has to be the worst idea ever, I have a 03FXDWG & getting to these plugs in the backbone is next to IMPOSIBLE I had an earlyer post on this & after trying to get to these Im ready to go nuts!
I assume you are talking about pushing the Amps and the harness back up into the frame from below. Yes it is somewhat akin to stuffing a giant octopus into an ice chest.
It helps me to go slow and really look (and feel) for hollow areas to stuff appropriate sections of the harness. You may have to pull it all the ways out and then feel around to see where you want to shove each section.
Or are you pulling something new down the entire backbone, if so excuse me for misunderstanding.
I doing it on an 07 FXD now, and the connectors are the most aggravating part of the job so far... Got the left side out, the right is stuck, I'll back at it again after work tomorrow..
Well the job got easier one I found there a plastic cover on the underside of the down tube right behind the neck...
I did not see your previous thread but are you saying you got left handlebar wires and AMP connector out of the frame before you realized there was the plastic cover underneath ?
If so, you must have pulled it out the cable hole after removing the rubber grommet ?? That is amazing you found it and pulled it out that way.
You definitely need to be pulling those AMP connnectors out the bottom (after removing the plastic cover) and then only after the AMPs are disconnected should you be pulling the wires out thru the side holes.
