R_W_B
Senior Member
I am relocating my front turn signals on my 07 Street Bob. I have the AMP connector apart (pulled down from inside frame) and the 3 turn signal wires out and taped up.
But when I try to pull (from the switch housing on bars) the 3 turn wire cable up thru the sheathing, it's not budging. I put slickem on the wires down under the frame but they have not moved 1/16" of an inch yet.
How does that rubber bushing (where all the cables) in the frame neck come out?
I am thinking if I could get that out it might loosen up the friction or if I had to I could take all the wires loose from the AMP conn's and just put the whole sheathing out from the frame.
Appreciate any help with this.
