Hoople
Account Removed
I think I will have to replace this IAC.
TQ, you may want to try this. Using the throttle grip, open the throttle body 100% and duck tape the grip in that position. Now wad up some paper towel/rag and shove it BEHIND the butterfly (intake runner area). Remember there is an IAC intake hole before the butterfly (air cleaner side) and also IAC hole (output) after the butterfly. When you boot the ECM with a power on signal and then turn it off, that will force step or parks the IAC. Try flushing while you boot and park the IAC a few times. Spraying into the air cleaner side IAC hole, the fluid should come out the IAC exit port.
The ECM must be turned off for about 10 seconds before it will re-intialize the IAC stepper and park.
Sometimes working the motor while flushing helps. There is a lead-screw on the IAC stem that you can only get clean by removing the IAC from the TB intake and brushing it.
