I have an 03 Ultra classic. My pin does not show up in the odometer, only the mileage. It instead is shown through flashes of the red security key symbol on the panel and flashes of both blinkers. You have to have a working fob to change it, but you don't to manually disarm it.
1) kill switch: off
2) ignition switch: on-off-on-off-on
3) left turn signal: twice
4) key fob button: twice
Both blinkers blinked once. Indicating the first digit of the code. I then pressed the left turn signal once and the red key flashed once more than previously. Count the number of times it flashes and that is the selected number. Double click the fob if that is the number you want.
The blinkers will blink twice, indicating it is on the second digit of the code. Press the left turn signal and count red key flashes, each press of the left signal advances to the next number and the key flashes correspond to the number. Double click the fob, when the red key flashes the amount of times for the number you choose.
Continue pattern to set digits 3-5 of the code.
Turn ignition off when done.
To manually override:
1) ensure system/alarm is activated
2) handle bar kill switch: off
3) ignition switch: set to accessory (not ignition)
4) turn signals: hold both immediately after turning ignition switch to accessory.
The red key will begin flashing quickly and the blinkers should blink once. Press the left turn signal until the red key flashes the number of times for the first digit of your code. Press the right signal. The blinkers will flash twice indicating it is on the second digit. Press the left turn signal and count red key flashes for the appropriate number. Continue the pattern for digits 3-5. After entering the 5th digit correctly, the system will disarm.
I have learned that if you know your code you can just press the left turn signal the number of times corresponding to the code followed by the right signal to enter it. You dont have to count each flash. EX. if your code is 1-2-3-4-5: after you turn to ACC, press both signals, get to the rapid flashing red key symbol- Press left turn signal once, right signal once, left signal twice, right signal once, left signal 3 times, right signal once, left signal 4 times, right once, left signal 5 times, right once. This disarms the security on my 03 Ultra. What ever your code, you input it with the left signal, and accept or enter it with the right signal- one press per entry.
