Yep. Starter engages, and I hear the cranking, but there is no "fire"... lacking a better description. Not sure what you mean by "turning over or not starting".
I even tried silly testing it.
Attempt at normal start (everything in place, as it should be):
Starter engages, engine will not turn over. I know the starter is engaging because I also tried starting in gear, WITHOUT pulling in the clutch... bike jumps forward.
Attempt to start with plugs in heads, BUT wires from coil NOT connected:
Same result...Starter engages, engine will not turn over. I also tried starting in gear, WITHOUT pulling in the clutch... bike jumps forward.
In my thinking, that eliminates the starter as the problem. It also means that "no spark" is the problem (because it acts the same, with or without wires connected).
So it HAS to be bad plugs, bad wires, bad coil, or bad crankshaft sensor (which tells the ECM not to let the bike start). Does that sound right?
BRB, gonna go try wiggling the cable bundles, in case it is an intermittent short...
Tried starting it while wiggling the cable bundle... thinking there could be a short in the Crankshaft Position Sensor... still wont start.
Took off right access panel, found where the Crankshaft Position Sensor cable ends, and connects to the ingition system. Opened the connector, and checked resistance TO the sensor. It was "Infinite / Open". It should have some resistance, RIGHT?
Also, I checked the engine codes... there are none stored. However, all my Google searches say that when the Crankshaft Position Sensor fails, it usually doesn't throw a code... so I could be on the right track.
Any help is appreciated, especially if someone thinks I am going about this wrong!
