D
dbmg
Guest
The only advice I have is that Dolt is spot on with his bearing advice. When mine failed at 24,000 miles on my 08 the noise was ever getting louder with increase vibration. On a slight grade engine off bike in neutral coasting down hill it sounded like a truck with mudder tires was following me. When dealer repaired bike I question type of bearing installed and the part number was the same as one removed. So I guess in another 20,000 plus miles if not sooner the bearing is going to fail again. The bearing surface was pitted and discolored. The dealer tried to make light of the $500.00 bill by stating that there was nothing I did to cause failure.......
