RibEye
Senior Member
Fuel rail pressure test is next. Requires a special set-up that will go in-line with the fuel line and tank, at the quick disconnect. Do not flex that section of fuel line. It is not designed for much bending. If it is not intermittent, take it to a dealer, or reputable indy for the test only. It will cost you the minimum hour labor, unless you have a gracious service provider. Pin holes in innner fuel lines are so common, I would be very surprised that the dealer would not have one in stock.
HD won't sell you the set-up. Some have built their own. I have an indy around the corner from me that will do a test for a few bucks. You might get lucky too.
Sorry. No way around the fuel pressure test, if you want to know for sure. refer to above posts, depending upon pressure test results.
Enjoy,
Rich P
Enjoy,
Rich P
