CalgaryBikeBum
Sorry been busy doing my 103 build so didn't see your question. When you change the crank you also have to change the pistons (stroker pistons). If you don't then the stock pistons will come to far up in the cylinder. Thereby being "proud" of the cylinder top and probably smashing into your valves etc? Sometime that is desireable (High dome pistons) to get more compression but that all has to be allowed for or you will get a loud bang/crunch and she won't be running. There are lots of good places to read up about "stroking" the engine. Its been done for years. In fact in the old days they used to put Indian cranks into harley cases to make a stroker.
