Can't do it now cause it's all together. When it blew up, I thought I'd save some dough and get the parts myself. I chose Accel cause I figured they been doing it for a long time and I trusted them. I ordered the stator & rotor for what they said was for my year. When I got them, the stator seemed like it'd work, but the rotor had no holes in it to bolt up the compensator. I called Accel and could tell the guy just figured the part was ok and that he was just talking to a moron. Anyhow, he told me to send them back for a refund. I did. So I figure it's time to bite the bullet and get the OEM Harley parts. Now, my bike's been splayed open for a week, so when the parts came in I was ready to throw them in. The rotor was the new welded part. The stator was about twice the thickness of the original. I figured "Wrong part again", (what a surprize). So I brought everything back. Old & new rotors & stators.
I had three mechanics standing there scratching their heads. The new rotor is so fat that it hangs offa the collar a little. So they start looking up part numbers. Old numbers, new year numbers service bulletin numbers. The outcome was "This is the right one" and I had to use longer stator bolts cause the stock ones that went through the old stator wouldn't even make it to the bolt hole through the new one. So I figured, ok, these guys do this stuff every day. If they say it's right it's probably right. Went home, bolted everything up and it worked. That was that. But as I mentioned on this forum when I first did the job, I always thought it didn't sound right with the new stuff in there. So much so that the next day I tore it down again to check that I didn't miss anything, and that everything was torqued by the book. I've put a couple thousand miles on it since so it does work, but I was never happy with the sound, I just put up with it.
Yesterday I brought the bike in to have the fix put in for the front end clunk. The mechanic took about fifteen minutes to fix it. He tested it up & down the street. When he came back he said "Clunk's gone, but you got something going on inside the primary." So I ain't crazy, something ain't right. I called Milwaukee yesterday when I got home and it sounds like they don't want to do anything for me.
If this noise has been the result of the wrong stator, I am gonna snap.
