free website stats program 07 low idle speed after warmed up. | Page 3 | Harley Davidson Forums
Sorry for late reply I did the sea foam cleaning took the sensors out of throttle body cleaned them good with Throttle body spray cleaner,ran 1 tank with sea foam,then tank with marvel mystery oil.Bike seemed to be doing better but finally happened again, I had new battery installed before all that.I have noticed that my voltage will also drop once bike gets hot I have a Ark audio amp added which was designed for the harley stereo not sure if that causes the low voltage but now I will be looking to test out voltage reg. and the stator,The low voltage not always same time low idle not sure if there is any connection. I will say though the low idle speed has seemed to occur less often and bike needs to get higher in temp kinda like when it 1st started long time ago.
