The Andrews 48 and S&S 551 ez start cams were designed for broad torque in the 96 inch engines. I have seen dyno sheets with some really nice flat torque curves from using them.
Impressive. What other tweaks were present?The SE203 cam is an H-D cam but I forgot that it is not available for the later models. The SE204 is available however and is a better cam IMHO. I have seen some 96"ers make 100TQ/95HP with OEM heads and those cams.
I have not been into that part of my engine as yet. But, I have heard that you can get the pushrods out, by removing only the rocker boxes. If that is not true, and you have to pop the heads too, you might as well go for a port and polish while you're at it.Thanks for all of the advice. I am sure it needs a camshaft replacement. I will have to do some reading, I have asked several guys in my area. One fellow says use gear drive and I liked the idea but the pressed together crank nixed that idea , or it seemed to do so far me. I asked about the kits that do require cutting the pushrods some like the idea some don't , I don't have any experience so I read and try to make since of all of this. I really appreciate the advice Jim
Enjoy,
Rich P
Just my 2 centavos...
Enjoy,
Rich P
I have seen the video before but as you said you get something out every time , In the video the crank was out .007 and in spectEach time I watch this video I get something more out of it.
Cam Replacement on a Harley Davidson Twin Cam, including Pushrod Removal • J&P Cycles
It's kinda long but, worth it I think.
I would like to upgrade my cams too. But only because I haven't done it before, and because I think I can.
Cheers!
Ferrous
I have seen the video before but as you said you get something out every time , In the video the crank was out .007 and in spectjust how much before you wipe out the oil pump . . What is the doing to the crank shaft bearings? Of course gears could not stand that abuse. For very long
I know most bikes or ok but would you do that also, At what point do you fix it .013 I sure would not just install a stock crank. I was told by a I consider smart guy tell me keep doing what your doing and you going to keep getting what your getting.
Of course that just my experience Jim
