Hoople
Account Removed
If the pump did not help, I would get the 12mm adapter and perform the compression test just so you can mentally put that off to the side. Then Test with propane for any vacuum leaks. Then get the cables and software and slap your own fat A/F fuel map to the ECM that you KNOW should work. At that point you should have a handle on the problem.. Then and only then place the original map back in the ECM.
Have a nice vacation.
