Check all fuses , be sure alarm is de activated than try this.
Un plug a injector. Use a test light on the injector harness, in line, put a wire into 1 wire connector and connect the lead from the test light to it and touch the light probe to the other pin in the connector,.
Put a spare spark plug into a plug wire, ground it to the block. Power and ignition on, crank the engine and watch both test light and spark plug.
No blink and no spark at the plug may be the crank sensor.
If the ECU doesn't know the engine is turning over you won't have spark or fuel.
Good luck
