2007 Night Rod Special, went off on one cylinder & i`m getting DTC PO 264 Rear Injector High, i've tried swapping the injectors round & she went ok for about 100 miles, off on the same fault again. Have checked the wiring for obvious damage & see nothing wrong, any ideas?
I did have to replace the battery last year, couldn't get a genuine HD at the time so fitted a Bosh 12v 12amp, should be a HD 12v 19amp, could this have something to do with my problem?
Also, when i bought the bike (new from a Harley dealer) i asked for a stage one upgrade, fitted a Thunderheader pipe & thought that was fine, while checking out the wiring i discover that the V&H Fuelpak management module was fitted under the pillion seat but never actually connected, needless to say I'm absolutely furious with the guy who should have done the work:bigsmiley19:
If & when i get the injector problem fixed I'm gona have to check to see if i`ve got the correct map programed into the Fuelpak.
Many Thanks
Tom
