J
Jack Klarich
Guest
Put a new rear tire on as it was close to the wear bars. Ran 34 lbs front, 36 lbs rear. Discovered that the local HD dealership whom told me that all Dynas handle this way had obviously not checked the axle alignment and neither had I to detailed specs. The rear tire was offset to the right while sitting on the bike. I aligned the axle and adjusted belt tension. Traveled 500 miles this past weekend and about 75% of the stearing wobble went away. Also noticed that the bike did not follow the Black Snakes in the pavement near as bad. Not done yet so will advise as to next find and cure.
Sounds like you have a good plan:s
