Not trying to be argumentative about the oil but I have put a lot of time behind a wrench and only relaying what I have experienced.
Me to Glider. I am just going by some bad experiences I had with the oil.
I probably should clarify what a "failure" to me is. By failure I don't mean the engine spun a bearing or threw a rod. To me a failure is premature wear on a part that should not have wore out in the period of time it was in use. All my failures were pre-mature worn out parts.
This particular problem may have been caused by adding too much gas treatments (injector cleaner) in my tank so I don't know if it was self inflicted. But here is 1 example from years back...
I bought a new Acura Legend V6 & ran dino oil till 7K because everyone I spoke to said you have to break in the engine with dino oil because Mobile 1 is just too slippery.(??) Now imagine what I am thinking. I have to wait to 7 thousand miles because this oil is "Just too Good"! Ok, so I break in the engine with dino oil (7K) and then switch over to using Mobile 1, 10/30 and change the oil every 2,000-2,500 along with installing Genuine Acura oil filter. This engine had a 6 qt oil pan. Glider, I took car of this car like it was my baby. NEVER overheated the engine. Only driver was myself. All hoses/ vacuum / water/ filters/ impeccable maintenance. You could not baby a car more than I did.
At 75 thousand miles the engine started having a rough idle. It continued to get worse, then at 85,000 I decided to fix it. Low and behold, the compression was gone. I took a cylinder leakage test on it and had 22% percent leakage in two cylinder and 18% in 4 cylinders. On the 4 cylinders that had 18% leakage, NONE of it was going pass the valves. ALL of it was past the rings.
I had friends who also had this same engine. This engine was also used in the English Sterling. It was a proven motor. My engine was shot. It was loose as a goose.
I know this is not enough conclusive data to say Mobil 1 is not a good oil. But to me, if it can not reduce cylinder wall wear or ring wear from splash oiling, what good is it. Remember the oil pump is out of the picture in this case.
Changed oil every 2500 miles, Mobil 1, Never overheated, oil pump out of picture,18% leakage pass the Rings Only. I should have took off the heads just to see what was inside but after thinking what I spent on changing the oil every 2500 miles ($35 X 30+ times) I just dumped the car.
This is just 1 example and I would never come to a conclusion based on 1 example. There are others. I just can't afford to keep giving that oil another try.
I don't know. It's probably me because others have gotten great results from it.
