Newer (all "vapor recovery" and "drive a way protected") setups will give you 91/93/87 whatever you order...
Here's how they work...
First customer of the day drives in, slides in his credit card, pulls the handle out, presses octane buttons, and the pumps load up. He squeezes the trigger, reducing system pressure, and they kick on, pumping fuel.
When he finishes and replaces the hose handle, a sensor reads an increase in pressure, and the pumps back off. Most of the systems then wait until the transaction code is processed, and then depressurize the unit & hose clear down to the one way valve (next time, look at the hose. See that metal ring about 2 - 3 feet from where the hose comes out of the housing? That's a combination valve/breakaway.
So, you drive up and order up some 93... there will be a few drops of low grade, but that's it - a few drops, nothing more. Pull up to a newer station today & squeeze the handle - that's exactly how much "previous grade" you'd get from the last customer, just a few drops will dribble out.
