I had the 103 Stage 1 kit installed on my 07 96ci Road Glide. I installed the V&H 2 into 1 with a (gutted) SE Slip on and had the Stage 1 103" Harley download done. Like you with just the Stage 1 kit, I was disappointed but with the free flow exhaust, my bike Dyno'd at 85hp and 98ft.pd. of Torque, I put the Power Commander on it and it made no noticable difference.Hello - I have the new Limited, it comes with 103 cams.
I did a stge 1 - V&H monster duals, SE air breather, Supertuner and then put it on the Dyno - Max HP 70.90 Max Tourque 81.40 - a little disapointing...
Come to find out HD is now putting the Catalytic converter in the header pipe and that is preventing the free flow of exhaust gasses. V&H just came out with a true dual header pipe and I am thinking of putting them on and changing to 255 cams - that should change my Dyno numbers.
Even with the low numbers the bike runs strong and sounds great
OK, Let me backup here, I mighta made a Fool outa myself. My mechanic sez "The reason the 103" kit raises the compression is because it increases the Cubic Inches causing a higher compression ratio."Why is the Compression Ratio higher then? I think the factory 103 has gotta have either different Heads or something, I don't think the Stage 1 add on kit will raise the compression. Where's DOLT when ya need him?
