Have witnessed 119/119, SAE, 103", set at 11.0 cr, with a set of heads that pull 155 cfm @ 10" at .600" lift, with a Wood 9B/44mm cv carb/DTT ignition/Thunderheader.
Mid-120's square, SAE, with 107" (3.934" bore), Wood 9B, 55/58mm HPI Max-Flo 1.800" intake port, D&D Fatcat BB baffle. Those 2" valve heads pull 170-173" at 10", at .700" lift.
Keep an eye out for an American Iron Magazine issue(s) with a 98"er that rolls off 119 hp and 112 ft lbs, pulling though a lousey air filter.(122/144 with correct filter)
I'd be interested in seeing the dyno reports, with weather conditions, on that Squeallin' Seagull kit, that produced those numbers.
Scott
