I just read this today 11/13/08
I would think the stator.....
I could SMELL the oil BURNT
My light also went off and back on
BUT the oil in primary *** OOOOOFTA!!!!
I replaced stator-voltage regulator - battery.....
after i replaced the stator ... the regulator was putting out TOO MUCH juice to OLD battery....
It was TIME for all 3
2000 fxds
THIS might interest a few of you.....
I bought a new 2006 1200 roadster
took it to az.
to save miles put on my dyna 2000 (built hot rod)
bore 95- 10.25/1 pistons- flowed heads- larger manley springs and valves-570 SS gear cams- fueling oil pump- delcron support plate- se'e' progable ignition- larger intake manif.- 42 mucuni-scm'e air- python 3 exhaust..
installed a 6 speed gear set- USING STOCK HD SPARKPLUGS
2006 SPORT
I went thru 4 stators and voltage regulators in 2.8 yrs with a normal 2 yr warranty.... SYORY
at around 8 mos the first stator BURN out.... I call that # 2 (warranty)
then at 1.9 of the warranty the second BURNT out #3 (warranty)
at 10 mos. later with NO WARRANTY in place ANOTHER call it #4
I talked with customer service and told them about my problems.......
asked if they had PROBLEMS with 2006 bikes....
NO was their answer BUT they woul discuss with their people.......
I got a LITTLE push and shove with them and said I WOULD expect them to get to bottom of the on going problem....
They called back an agreed to HELP OUT with the repairs.... It was a WEEK before sturgis 08 and I planned to go this year....
I took the bike to sierra vista hd in az. but it TOOK 2 weeks of time to do what ever hd and the shop did ?????
I made sure they (C.S. H.D.) understood *if they wern't going to pay for it I would rather do the work MYSELF and save on the labor.....
They assured me that they would HELP... NOT saying what HELP ment i was
LEARY..... ( note bike warranty over - oct of 07-- this was aug 08)
BUT the bike NEEDED repair.... at this time bike had 34,500 mi.... (I RIDE)
THEY found the stator was BURNT and did replace it TEST-TEST- ????? looking at ignition key switch.... and wires... found nothing .....
NOTHING was found to say THIS caused the problem.......
THEY (factory HD) had the hd shop
REPLACE STATOR
REPLACE VOLT REGULATOR
NEW BATTERY
AND H.D. factory PAID FOR ALL ABOVE PARTS AND TEST LABOR....
BUT i was billed for the labor to install the stator-v reg.- and bat.
NOW when I think about it...... do YOU THINK THEY should of paid ALL???
The problem may pop up again and if so there still is an UN-FOUND problem....
