Davidw2415
Senior Member
Kinda makes you wonder where the by-products of combustion are going. Oil does not get Black or Dirty on it's own. It get dirty because it is trapping and holding the by-products of combustion that get past the rings (which does and will happen to the best of engines) until you drain the oil. If the oil drains translucent it would make me wonder if the carbon is still in the engine.
I'm with you TQ. I would never go to 5K on a change. My oil drain dark brown at 2500.
Well let's see I stated that the oil was translucent not clear or clean. there are various stages of translucent. If I let some oil run on my finger as it is draining and i can still see my finger though the oil I consider it to be translucent. As far as the byproducts of combustion, I would assume, and hope that those expensive Hd oil filters are doing what they are designed for, and filtering most of them out.
When I was in high school I took a work study program though Standard Oil Co.
One of their factory Rep's Came in one day to talk on their products. One of the first issues he brought up was that the biggest factor in oil turning Black was heat, not contaminants. And I always assumed that since it was his job to know, that he was probably right. So if this is right, and one of the benefits of Syn oil is that it is supposed to old up to heat better than conventional oil that it should be safe to think that it would not turn black as quickly as conventional oil.
I've been driving for almost 40 years now and have always done my own oil changes and before doing so on my own vehicles I started dong oil changes on my Fathers cars when I was probably 12 or 13 years old and based on my experience over the 10 years or so with the more efficient engines and higher quality oils, it just doesn't get as black as it used to years ago. In fact I really can't remember the last time I changed the oil in one of my vehicles and the oil was Black. I would hate to think that I was paying double for syn oil over conventional if I couldn't expect to get better service out of it. But that's just me. I may go back to changing every 25 to 3000 k or not. depending on what kind of riding I'm doing.
Dave.
