Ok , it appears you guys are on the right track about the primary tension.... I took off the access panel and the chain was extremely tight. I backed it off and the whining almost went completely away..how ever now i have to much slack and i am having trouble getting the block to come up high enough ,it is like i am fighting to get it to come back up........
Glider, you have been a great help and thanks to all the other post .......you guys are a great asset to us new guys ,,,,it is greatly appreciated........
I usually use a Long 9/16 socket and to a little lifting and wiggle to get it back up... IF I New you were going to Loosen it, I would should of mentioned DON"T allow the adjuster to DROP... Like mentioned IF Loose enough (NOT TOO LOOSE) the adjuster can be coached into a proper position using the long socket and A finger or two... Tight I know.......... Remember,,,,,, They (adjuster and matching holder) look Like a BIG Bastard Files..... Fitting into grooves onto each other,,, so careful the file fits together Flatly and it will work fine..... error on the loose side(wee-bit for fin) NOT the too tight side... IF too loose , It will rub-smack the Inner primary housing and you will be asking??? I hear a Noise
I have problems with the adjuster also i normally manage to wiggle it up to the right tension and then can not get the socket in as the hole is full of hand holding it in place
when it gets to the point that i am getting frustrated with it i take the dog for a walk and it always seems to behave after that
