So heres where I am, Started the bike last night to try to pin point the sound, tried the screwdriver thing and I could not tell anything. Going to pick up a stethoscope today.
The bike would run decent with the choke on but once the choke was turned off the bike would cut out, if I tried to save it with the throttle it would still die, seems like it was not getting enough fuel. So I took off the carb and in the process of looking it over and giving it a cleaning.
This is the first time I have ever messed with a Carb, so should I use carb cleaner or sea foam to clean, or tear it down and just do a rebuild?
The manifold seal that holds the carb looks good. The thin rubber diaphram piece also look good. Even the screw heads and hardware look good, and I noiticed a Arlen Ness Big Sucker intake on the bike. Iam starting to wonder if this bike has had work done, there was also a washer missing on one of the crankcase breather bolts. The bike was real clean when I purchased it from a HD dealer, also was just recently repainted, it seemed like it was taken care of by the previous owner.
Iam starting to lean more towards the Ignition Module.
Once again thanks for all the input, I appreciate it!
