free website stats program 1995 FXDL Rear Wheel | Page 2 | Harley Davidson Forums
I'm with Breeze here, check the bearing size and then you have to have the correct spacing for the caliper and disc alignment.
Here is a picture of your (Wheels) and related parts
1 510 SPRING CLIP 1 1.49 0.99
2 3730A BOLT (CAST WHEELS ONLY) 5 1.49 0.99
3 5756 SPACER 1 1.49 0.99
4 6516HW WASHER 5 1.49 0.99
7 7987 CASTLE NUT 1 2.49 1.99
8 9052 ROLLER BEARING 2 18.49 15.49
9 40217-79A SPROCKET, 70T (BLACK) 1 217.99 180.99
17 41015-86 WHEEL ASSEMBLY, 16" CAST - 9 SPOKE (BLACK) 1 353.00 292.99
19 41114-90 AXLE 1 76.49 63.49
20 41123-79 VALVE CAP 1 0.99 0.49
23 41591-90 SPACER, REAR AXLE - LEFT 1 26.99 22.00
25 41789-92 DISC, BRAKE W/ REF # 31 1 122.99 102.49
28 43157-83A VALVE STEM ASSEMBLY 1 6.49 5.49
29 43290-82 SPACER, 0.032" THK. 1 1.99 1.49
29 43291-82 SPACER, 0.016" THK. 1 1.49 1.49
29 43292-82 SPACER, 0.008" THK. 1 1.49 1.49
29 43293-82 SPACER, 0.004" THK. 1 0.99 0.99
29 43294-82 SPACER, 0.002" THK. 1 1.99 1.49
31 43567-92 SCREW 5 1.99 1.49
32 43608-82 SPACER, (CAST ONLY) 1 18.99 15.99
35 43650-82 SPACER WASHER 1 7.99 6.49
36 43654-86A SPACER 2 35.99 29.49
38 47519-83A OIL SEAL 2 3.49 2.99
41 95594-84 WEIGHT, 1/4 OZ. (BLACK) 1 0.99 0.99
H-D INTERNATIONAL ONLY -
9 40311-94 SPROCKET, 65T (SILVER) (SWISS)
Note: The Dyna rear rim sizes in the link in post #10, do not agree with the rim size at the top of post #11.
Thank you all. My next step will be to check the bearing and axle sizes.
One more question...How do I measure the size of the spoke rim I now have? I know it is 16" . But from where to where do I measure to determine is it is 3" or 3.5"?
Thank you,
JB
Thank you,
JB
Inside shoulder to shoulder, most wheels are stamped with size:s
