Hey everyone ,I got home early today and backed this bike up out the door a bit and tried to fire it. About the same happened except not nearly as much backfire out the exaust and carb. So i did loosened the ignition cam sensor and just kinda centered it.The bike fired died ,fired died,backfired some,made a few flames out the exaust........then finally with me holding throttle open i was able to get a few minutes of it running(rough but running) .(Good news right?) So what is this telling me? Static timing says its good on the twin tec module but its not? Timing is off?way off? So now that im here to where it will run a few minutes i feel like i need to fine tune somethings? Start up settings for carb? Set the idle ? Set the mixer screw? The jets are 190 & 46? And what about the timing? What to do about that? Not much experience with timing stuff but ive learned alot so far so im getting more educated on it.. I want to set it up to where next firing i know idles set ok ,mixer screw is ok,then timing? Thanks everyone
