As promised... am reporting back. Sunday I took the battery out and inspected the cables. The battery is only 3 months old (I change batteries every two years regardless) and the cables are new too. All looked fine - no corrossion.
In removing them, I found the negitave side to be a bit lose, so that may have been the problem. With my limited tools and knowhow, I could not get get to the positive lead to the starter. So far 55 miles later, no problems, pray that continues.
Thanks again TQ for the heads up on the order of removal and replacing of the battery cables - did not know there to be a right way to do so. However, you failed to mentioned that a large spark and BOOM would occur if one drops the negitive cable across the positive post! That was shocking!! My pretty new battery now has a chunk of lead out of the positive post.![]()
What was still connected to the negative terminal to cause this?
There should have deen no spark if the negative cable was already removed
