BUBBIE Well-Known Member Mar 18, 2014 #11 Sport40, Now that makes sense... I think you found it... Movement and touching will do that noise... Good Call on your part. Learned a bunch here...Tks. signed....BUBBIE
J Jack Klarich Guest Mar 18, 2014 #12 Good deal, as long as you are back in the cam chest check your breather if it is plastic have a look for scoring in the cam chest and recheck the end play there as well
S Sport40 Member Apr 4, 2014 #14 I installed good dimension shim on camshaft today. The motor run nice without noise :small3d026:
J Jack Klarich Guest Apr 4, 2014 #15 Sport40 said: I installed good dimension shim on camshaft today. The motor run nice without noise :small3d026: Click to expand... Good on you
