Breeze3at
Experienced Member
Thanks for the info! The seat is a 2 up one piece seat not a solo. It has the fastback style passenger area. The seat will install but there is a little pressure when installing the rear fender nut. When you loosen the nut the rear of the seat will rise up about an inch. I will call Lepera.
All of my seats need a little pressure on the seat tab. You can tell if those bolt heads are the problem by putting a dab of clay,grease, chalk, paint, etc on the bolt heads and put the seat in place. Sit on it, then remove and see if the marker material has transferred to the seat base.
P.S. I would have recommended a piece of carbon paper & paper, but I haven't seen any in several decades.
