free website stats program 2001 Road King Police - Need Help | Page 2 | Harley Davidson Forums
Have you misted water on rear spark plug wire to help in finding short to ground at idle.
If no spark from a plug first replace the plug then the lead and you can always swap over the plug leads at the coil and see if the problem moves or stays
Do not remove plugs and ground them, The ECM needs to see compression to fire the plugs, best to use a spark catcher
