Re: Hello from Kansas
so between your March 25th and your last post - have you changed any fuses , put a good Amp/Ohm/ Volt meter to it , have you checked ALL grounds , have you checked BOTH ends of your batt. cables , have you had the stator checked , did you make any mods prior to the problem........ ????????
What will cause my bike to shut down while riding? I have replaced the coil & it is still doing it. Today i started it and before I could get it out of the garage it died. I pulled a plug wire and put another plug in the wire and ck'ed if any spark and nothing. Need suggestions
I ride a 03 883 and am having a bad time of trying to locate why my this thing dies while riding down the rode. I've replaced the coil, cleaned the carb, removed the tank & cleaned the screen, & ck'ed the wiring the best I could. The bike will die at irratic times. It will crank over right after it dies but will not start until it sets for awile, & the waiting time will very. I'm thinking it could be a circuit breaker or one of the many sensors that they thought they had to put on this thing.
Does anyone out there have the answer?
