jmpancoast
Is the tranny and primary case fix at cost to the owner or the Moco? I don't even know if my bearing was ever done. Nothing shows up re: my bike on the HD maintenance search Glider posted.
I was told by an independent that my drive belt is out of alignment by 1/2 inch or so. I thought this might be due to the wide tire kit (I've got a 180 that was put on before I bought the bike). Could the Primary/Chaincase misalignment be my problem?
Typically the way it appears this fix is working, an owner has a problem with the IPB (first occurrence) and the dealer fixes after talking to MoCo customer service. Then the second failure occurs. Since the MoCo has already been involved and they are aware of numerous failures, they authorize the dealer to tear it down, verify problem, then order new cases and fix it at no charge to the customer. There is no service bulletin on this so it is being dealt with on a case-by-case basis.
What is meant by cases misalignment is that the position of the primary case has shifted where it mounts to the tranny case putting stress on the IPB because it is binding. This slight amount of shifting would not be evident without a means for precise measurement.
The belt alignment would be affected due to the install of a 180 tire only if the axle is not properly positioned in the swing-arm. One sign of this is improper positioning of the tire within the rear fender. Another symptom may be the belt whining, especially at slower speeds. This is easily fixed by following axle alignment procedures. Let me know if you would like specific steps for this. Its something you can correct yourself.
Just because the tire is not alignment with the rear fender does not necessarily mean your axle is out of alignment. Since the swing-arm is attached to the tranny, it could mean the engine is out of alignment,
Sorry for rambling.
John
