Nightmission10
Nope wont start by down shifting down and jump startingor dumping clutch, have to stop shut off 30 sec then turn on then hit starter and shell run fine ,, Thanks MIke
Pull all the fuses and check for corrosion. Clean and replace with some dielectric grease on them. Check BOTH ends of the battery cables for tightness and cleanliness.
Jack read bullitin woow awsome info Thank You..MIke
said code was injectors replaced and ran fine yesterday
